jpsr
- 1.2 channel master, cm polar mount, 12 inch actuator, Andrews feedhorn, Inverto lnb, Superjack positioner, Dreambox dm 500s, Protek 9600ip, 1m channel master with black ultra & 1m gibertini with technomate twin output lnb on astra 1/2, TM 5200 & 1000
- Mullingar, Ireland
After trying all over my garden with a smaller dish i cant get most of the lower sats like 42e,39e and some of higher ones like 1w because of the house next door blocking the line of sight, my only other option is to mount the dish on the side of the house, where my existing dish is, I wanted it on ground level.
I was going to use an L bracket which i have seen used loads of times with 1.2 cm's, especially bookies here who use them a lot.
Here is a pic of one, does anyone know if this is suitable for the 1.2cm, as this is a bit different.
The ones i seen before were the same only there were extra metal bits wealded at the base.
Also forgot to mention i am motorizing this dish and there will be a cm polar mount attached.
