Advice required
Andrew61
Likes
Skystar 2 PC card
Pentium 4
Win XP
Scotland
#1
Hi everyone.
I have a problem with my Sky reception and was looking for advice.I constantly get the " No satellite signal" sign on several channels, sports, films etc. I have spoken to Sky who say it is a transponder problem and need to call out an engineer ( £65). I can sometimes get it to clear if i switch back and forward several times between a free channel, 101 for example and the faulty channel. I have changed the lnb, and it seemed to cure the problem for around a week then went faulty again.
Sky box is a grundig. I asume that if it is a box problem i would be as well calling Sky as the £65 includes all parts etc.
Any advice would be appreciated.
Thanks.
J
jimbo101
Likes
Dreambox 500s
ENGLAND
#2
Go to A car booty and look for one I have found that the new card does mind being put into another box I have done it myself got a box from a carbooty for a £5 and and out my card in and it worked
Cheers Jim
S
spiney
Likes
Pace 2200 Sky digibox with ftv card, Comag SL65 FTA sat receiver, 40cm Sky minidish, Setpal terrestrial receiver (for free uk tv only!).
Midlands
#3
Various things this could be, a more detailed description would help!
(yes, a new digibox is often the esaiest solution, if it's faulty!).
1) Go up and down, though quite a lot of channels.
2) Is the problem random, or does it occur in a particular place/channels?
3) Is the box saying "no signal"? That's possibly a failing power supply.
4) Are you getting pixilation (breaking up into tiny squares)? That would be low signal, but a bit strange just on one channel if others are working!
P
pgh13
Likes
378
Midlands UK
#4
Is it happening all the time? We've had some sh1t weather this w/e with lots of cloud......could be reducing signal. Can you try your box at friends house? and vice versa? Car boot sounds good if you can find one at this time
H
handyman 44
Likes
sky digibox also technomate tm 1000 ci
motorised 80 cm dish
norwich "up the city" down the ipswich
#5
hi im told that if you tell sky you want to cancel contract because of said problem they will fix it for nothing . providing your not tied in to a contract . on the other hand they might call your bluff and take all away for xmas .
T
Taylor619
Likes
Sky Freesat
Panasonic TU-DSB31
AMD Duron 800
Windows XP
Nvidia Geforce2
128MB Ram
40 Gig Hard Drive
London
#6
Could be nothing to do with this but i had the same problem recently with my box , apparently to ther sites my make of box has a common fault being a person who owns this grundig box and a panasonic one , its most likely the dish has gone a bit out of alignment , this was the problem with my box , and after realinment it should work ok , i dunno if it may cure your problem , but try it , it might help
ps, excuse my bad spelling
L
Low Profile
Likes
DM800HD, DM7000 80GB HD with Asus WL330 wifi + 2GB usb drive, Skystar2.3, 2.2m Kinhuge Dish with Inverto LNB and Invacom ADF-120 feedhorn. Pace 1.3.25 and 80cm for Sky.
Lot, Dordogne, Correze border.
#7
is that the LNB isn't switching between horizontal and vertical reliably (which is why you get the channels sometimes, but not at all at other times). As mentioned, this may be the power supply. Personally I would have a look at the power supply and replace any capacitors that appear to be 'bulging', but if the unit is under 2 years old then I believe that it should be covered under warranty (European Law), so get the supplier / manufacturer to sort it out free - once you have confirmed that it is the box at fault.
Zorba
Zorba
Likes
7
3m(28.2E),1.5m(19.2E.13E,10E),1m (4W ,7W)1m (?).diseqc 10,sky plus,VU+,telergy iptv.
Satlook nit colour + Horizon hdsm.
Limassol, Sunny Cyprus
#8
Coincidently,my mate who fixes digiboxes had two grundigs in recently which couldn't get channel 5 and some others and the problem was some capacitors in the power supply.problem solved.
