Aerial cable for Freesat/Sky
taywood
SkyStar2 to PC and ProgDVB, DVBDream and to TM1500CI+Super
NW Lancashire
Is it narrower than normal cable?
Can I pull the older single cable out thru the hole in the wall and get two new cables back thru the same hole is what I'm asking.
No - its about the same. If you want to put 2 lnb cables in then you will need to widen the hole somewhat
You can if you use WF65CU Shotgun cable, it will just fit through a 10mm hole (if that's what you have).
My neighbours twin cables looked slimmer than my cable. I'll check the number rolfw gave. If I can't pull the two cables thru then its a case of paying an installer to do the drilling.
