AFN changes from Sept 1st 2011 - help for the military lads
We have had several threads started in the last few days about the loss of AFN programming from 13E. This is because AFN has moved from Hotbird 13E to Eurobird 9A at 9E.
Whilst each situation is different the fix is common to all our military lads - the AFN receive dish needs realigning from 13E to 9E, and the receiver(s) need retuning.
These are the threads running atm - you might find the info you need on them:
http://www.satellites.co.uk/forums/...fn-afghanistan-stopped-1-sep-my-location.html
http://www.satellites.co.uk/forums/...s/193555-afn-satellite-setup-afghanistan.html
http://www.satellites.co.uk/forums/...-motorised-systems/192992-afn-setup-iraq.html
http://www.satellites.co.uk/forums/...ystems/193730-afn-satellite-setup-israel.html
http://www.satellites.co.uk/forums/...ated-need-some-basic-satellite-knowledge.html
It strikes me as very odd that AFN hasn't widely promulgated (there's a classic Military expression!) these changes well in advance, to those who might be affected, like, errm, American Forces abroad.
Isn't that classed as a SNAFU ? (another classic military expression I believe)
Considering AFN has been running for MONTHS on 9E all camps have had plenty of time to get the dishes moved.
(According to KoS AFN launched on 9E way back in mid May.)
The info obviously hasnt got to the blokes who run the receive systems in some areas.
A breakdown in military communication? Fancy that eh... :D
Heck, they only have stick 'AFN' into Googoyle and the first hit will take them to the necessary info.
ralphmagno said:
hello, afn anounced the change 18 may 2011.
june,july and aug over 100 days.
ralph
I'm glad to hear it - but why are we getting so many urgent requests for assistance?
let see who is take two transponder from hotbird
will be nice if will be new hd channel
hello,
i heard silivio belsconi will get it for mediset premium will get the old afm frequencies.
ralph
The AFN switch from Hotbird to Eurobird was widely publicised on AFN networks (sat and radio), however, the transponder they have chosen is the weakest signal in a 5 degree arc (6 different satellites if I remember correctly). This means that we are all trying to find the WEAKEST signal in the area. Also, the garbage receivers that are available are VERY picky about signal levels. Trust me, have done over 2 dozen in the last month.
Signaldog
hello, they know the signal is weeker.
i have done a lot more than 2 dozen here in naples.
all transponders on that sat are lower than hot bird.
if i mesured the afn lobe at the dish i would get 66 db on hotbird with the average lnb.
on 9a i am getting 59 db.
but i still get a signal quality of 4 to 6 where i was getting 6 to 9 on the decoder.
this is from a 80 cm dish.
i have set up afn on a 60 cm dish and realigned a 30 cm dish with short runn and got it to work.
afn last weekend started sports hd on channel 801.
if you got the new decoder you picked it up.
it will be years probably 2015 or so until afn is 100% hd and all the old decoders can be tossed.
ralph
ralph
Thats weird - EB9A is the old Hotbird 7A so should be chucking out a HUGE signal. No problems with the signals here in the uk :D
