Allrussian help
Pt101
dm800se
dell inspiron
homemade 6 core amd
Uk
Hi all.
I have an 800se with an allrussian image, got it working how i want after a load of fiddling about, i have cccam 2.1.4 and 2.2.1 installed and i get glitching, my internet is not that fast and i was told that cccam 2.0.9 or 2.0.11 may help as it uses a lot less bandwidth than the versions i have.
The blue panel download is down on my box i have tspanel on there it has lots of cam sections on there but not for the allrussian, does anyone know what image it was based on or other images cams may work?
cheers
If you get glitching that is due to the server being overloaded. If it is a commercial card share you won't get help here.
Ok well u assumed wrong, firstly It's not a commercial server.
Secondly are you saying my under 512k broadband is not contributing to a bandwidth issue. Seems to be worse if anything else is on the Internet? Took the box to a mates and it was fine there.
Ergo why I asked a question about the lower version of cccam? we are not all on commercial servers and 20meg broadband.
Thanks for the helpful reply though.
Sky UK is very sensitive to bad Internet connections, although a 512kb broadband will be no worse than a 20mb one - it's the latency that counts.
Check your ECM times from whatever share you are using. Anything above 350-400ms will cause a glitch...
If you want guaranteed service then buy a proper subscription to the pay channels(s) you are interested in. We cannot give you any detailed help as doing so could lead to the forum getting closed down.
Your problem seems to be a slow update when the keys change on the service. This is a common problem where the card is overloaded with too many folk connecting to it, although a slow link in the bb connection could also cause the problem.
Thread closed.
