amos
live2dmax
Hi ,
I have a motorised sys. and i try to get some romanian programs on amos1 and 2 . I have all the frecv. and details of the programs but i can`t get them , i can get signal on other frecv. , any sug. ?
Lancelot
Retired Mod
SS1.
36v H to H 62E - 61.5W
South central
It really depends on where you are and what equipment and dish you have there, you may be on the edge of the footprint. Amos 1 is very difficult to recieve here in the UK if that is where you are. :)
L
live2dmax
I have a 1.1 dish and live in cambridgeshire :)( st. ives) .receiver is a technomate5500d.
Thanks for reply ,
QUOTE=Lancelot]It really depends on where you are and what equipment and dish you have there, you may be on the edge of the footprint. Amos 1 is very difficult to recieve here in the UK if that is where you are.
L[/QUOTE]
Lancelot
Retired Mod
SS1.
South central
This is the Amos 1 European Beam.
The beam centre has an EIRP of 56dbw so we will be lucky to get anything here without large dishes.
St Ives is at about 32dbw on this sat and 36dbw needs a 3mtr dish so you can see the sort of antenna you would need :)
Rgds
L
Forget Amos 1 . However, Amos 2 should just about be in range in Cambs. Which Romanian channels you after, you might be better off pointing a dish at 5E instead.
stevo
dreamboxhd 800 pvr
2 x dreambox 500s
globalstar-m6 free to air
1 metre dish
80cm dish
60 cm dish
all via diqsec switch.
england
ther are 4 or so romanian channels on 16 east tvr 12.714 v 9814 2/3 clear
tvr 1
tvr 2
tvr international
tvr cultural is in via 2
eutel sat 10 east
antena 1 11.o24 v 5632 3/4 scrambled
astra 5 east
12.697 v 14685 3/4 clear
etno tv
otv
realitea tv
tv-k lumea
tv sport
try this aswell http://www.flysat.com/tv-ro.php
stevo
live2dmax
Hi ,
Thanks everybody for ur help . I`m looking for 11415H,11432H,11655H,(N24 ,B1tv ,tvpax ) . If you know some romanian channels fta please let me know .
Fta Romanians:
h**p://www.digitalsat.co.uk/sirius.html
