Angle setting on HH motor
B
Blake Lane
Aston Simba HD,Triax 70 cm with HH motor
45 E to 30 W
France
Hello,
I search the mathematical formula that determines the Angle setting on HH motor. This angle is different from the azimuth angle in the case of a fixed installation.
At Belfast for example, the satellite Astra 19,2 ° East
the Azimuth angle: 150.08 ° (29.92 East) and angle setting on HH motor : 27,43° East
You can see this type of calculation to the following address: _http://www.pteelien.net/c50b
Thank you for your help.
Blake
futumsch
futumsch
80cm dish, Pace MSS500 (analog) 19e
1m Channel Master fixed 26e, 1m dish, SG-100 motor, Inverto Black Ultra. Pace MSP 200, Humax F1 VACI
Jaeger 1224 mid restored. Fibo 1.2m.
Midlands, UK
Hello Blake
Azimuth angle can be calculated by:
180+ ArcTan(Tan (satellite longitude - site longitude)/sine site latitude)
a tip: keep your longitudes in degrees west, i.e. so Dubai might be 305 west for example. and BADR4 at 26E would be 334 degrees west.
Remember to convert your degrees to radians especially if you are using Excel.
This assumes that the satellite has 0 degrees inclination. And this also assumes tha the Earth is a perfect sphere, which it isn't.
This is going to give you azimuth values that you might expect from the majority of satellite pointing angle sites like _dishpointer dot com, which are good enough for small diameter dishes with 1-2 degree beamwidths.
B
Blake Lane
45 E to 30 W
France
Hello futumsch,
Thank you for your answer but unfortunately that is not the formula that I want.
The calculation that I search for the position of the HH Motor arm. If you look at the position it where you oriented your antenna you will see that the scale is different from the calculation of the azimuth.
That's why I gave the example of a instalation in Belfast with an antenna pointed at Astra 19.2 ° E.
With the calculation : 180+ ArcTan(Tan (satellite longitude - site longitude)/sine site latitude). you get: 150.08 degrees East, while with the calculation HH STAB you get: 152.57 degrees East.
The difference is that the HH Stab is not flat but inclined of the value of the latitude.
Blake
There is a calculator at _http://www.satsig.net/sf.htm
One of the things it works out is polar mount rotation.
The code below is what it uses so you should be able to fish out the formula from that:
function rota(satlong,eslat,eslong) {
// new 26 June 2006 Strictly Copyright (c) 2006 All rights reserved Mitko, Plovdiv, Bulgaria
pi=3.1415926;
radius=6378;
horb = 35786;
rcentrum=radius+horb;
alfa=eslat*(pi/180);
rm=radius*Math.cos(alfa);
omega=satlong*(pi/180);
mu=eslong*(pi/180);
beta=omega-mu;
os=rcentrum;
oc=rm*Math.cos(beta);
ac=rm*Math.sin(beta);
cs=rcentrum-oc;
distx=Math.atan(ac/cs);
landa=beta+distx;
if (Math.abs(landa*180/pi) >90) return "n/a";
esrota=landa*180/pi;
return esrota;
Robbo
Robbo
Retired Mod
Gravesend,Kent,UK
Thanks, for that, it works very well, I have just input the equation into my favourite programming language. Also as expected if you input a theoretical 90 degrees latitude, and 0 degrees longitude the result is the orbital position of the satellite.
Is that PHP? If so I wouldn't mind having a copy.
B
Blake Lane
45 E to 30 W
France
:-worshipThanks thanks thanks and.......... thanks
M:W
Blake
Robbo
Robbo
Retired Mod
Gravesend,Kent,UK
No, 'fraid it's not in PHP, Labview actually, I'm not a proper programmer.:-rofl2
B
Blake Lane
45 E to 30 W
France
This algorithm is one used by motor equipped with the function USALS and Goto X.
Blake
Not the motor. The receiver works it out and sends the angular position to the motor.
futumsch
futumsch
Midlands, UK
Well, I like a challenge and with half an A4 notepad full of spherical trigonometry trying to work it out directly, I gave up. I could never work out inverse cosines anyway.
Then I opened my 'Practical Astronomy with your Calculator' by Peter Duffett-Smith. In there, is a chapter on horizon to equatorial coordinate conversion.
First find declination;
d = Arcsin ((sin a * sin L) +(cos a * cos L * cos A))
Then find Hour Angle (Polar angle),
H = ArcCos ((sin a - sin L * sin d) / (cos L * cos d))
Where
a=satellite elevation
A=satellite Azimuth
L=Observer Latitude
Then find Sine of the Azimuth. If sin A is postive, then the answer is 180-H. I can get the sums to work fine if the satellite is East of the observer, but if it is west, then you have to use 180-H.
Excuse my for a while while i detox from all that trigonometry...
S
Snuffer
Skystarcard,Fortec's life time ultra's, MaxPlus 2100's,Dreambox and a Tandberg
Amsterdam
Do you have this program working and can i get a copy of it????
