Annoying 7020 problem
You might have to use Dreamup and a serial Null modem lead to sort that out AS :-righton
I've stopped using the SatanKey updater as it did exactly the same thing to the image on my USB stick, I use the hacksat key updater now as it doesn't **** up your image, my appologies for not telling you sooner :-DOH!.
I would just put the newest Dream Multimedia image back onto flash and just boot the box from the USB stick with what ever image.
I did exactly the same on my 7020 once the warrenty ran out and its never ran better. Its even running Darkstar perfectly which is one thing it couldn't do before i put the newer image in flash :D
Just get it up and running on the base image and then leave the flash alone otherwise me and BG will be round to beat you around the head with a big stick :-rofl2
You can MSN me if you need to mate :)
:-beer
Nano
Cheers nano. havent risked doing anything fancy with the image since I finally got it running last night. I rather suspect satankey updater is the problem, although its worked fine for ages.
Havent even set my c/s details up again yet ;)
I think Ive got hacksat on the computer so will try that one instead...
Bl00dy DB receivers. I was tempted to take it over to the flood in field opposite our cottage and drown the ****in thing earlier in the week!
The Satan Key updater is a pain in the arse. If it can't DL the files it just ****s up the image, well it does with Gemini anyway :eek:
Didn't seem to do anything with my Powerboard Enigma one image or on my Pli Iolite image, just Gemini. Might be worth mentioning it to the Gemini team if i knew who they were :-lmao
:-beer
Nano
New hacksat v7a out today, I would warn against filling the flash image up with settings, emu's and everything else.
I would only ever put a cvs image in the flash and do all you farting about on the usb, can't break too much that way.
The other option is to use a backup image, ain't that right nano;)
Since I stopped playing with satan key updater it seems to have been stable. I plan to put a cvs image in central flash at some point and faff around on usb or cf card like I used to.
I wanted to make sure the bl00dy thing wasnt broken first!
