I've read the Dreambox 500 suffers the same problem, and that it's not the box, but a under rated plug-in power supply. Anyway apart from the motor control issue is there any other reason to avoid the Eagle Box? Thanks for all the replies.nanochickin said:Don't bother buying one if you intend to go motorised
Huevos said:Anyway apart from the motor control issue is there any other reason to avoid the Eagle Box? Thanks for all the replies.
Support through the "Dark Site" seems pretty comprehensive.Topper said:Old design
limited support
I haven't got an HD TV. What's the point. There only seems to be one channel.Topper said:Not HD
That's a problem with Gemini, not the Eagle Box, nor the clones.Topper said:Probably subject to same Gemini Image/Clone problem
I'm looking for an entry level into 4:2:2 (and maybe to experiment with IP streaming and CS). £250 for the most basic current Dreambox (without hard drive) seems a lot of money to me. What do you suggest?Topper said:Suppose you give me one good reason to buy one![]()
What do they cost?nanochickin said:IPbox200.
Huevos said:I'm looking for an entry level into 4:2:2 (and maybe to experiment with IP streaming and CS). £250 for the most basic current Dreambox (without hard drive) seems a lot of money to me. What do you suggest?
To find out other people's opinions and experiences of course. The Eagle Box would cost me 95€. For that amount or similar what else is out there that allows access to 4:2:2?Topper said:what is the purpose of the thread?
