emission
- Mar 31, 2005
- Age
- 54
Triax 110 TDA
Invacom 0.3 dB LNB
NileSat 7 W deg.
Swiss
Good Day
I live about 20KM far from Geneva, Swiss 46.24° N 6.14° E
I have Triax 110 Pointing to Nilesat 7W
I can get most of the channel " about 100 Ch" with normal LNB
Two days ago I bought Invacom 0.3 dB High power LNB for more performance but still I didn’t fix it .I have heard that Gregory antenna has an additional sub reflector and the antenna efficiency and gain of this antenna type increased by using " Gregory double focus principle "
Example : The antenna efficiency of an offset Gregory with 90 cm size corresponds to a normal 110 cm offset antenna
Now my question is :
Is it possible to apply this method on my Triax 110 Dish ?
I mean is it possible to fix any Gregory antenna arm " sub reflector "on my dish ?
To get more performance , if yes anybody try it and how ?
Thank you in advance
