Hi is arab sat stronger than 28.2e, i get locked on 26.e but im trying to get 28.2, if 28.2 is stronger then i might be on 28.2. Have not checked on sat box as i was busy. What is the quickest way to get 28.2 im using a first strike meter. Thanks
Down approx 0.5 degree, rotate 2 degree East, try using Sky News on 12207 V 27500 as a primary lock.Hi is arab sat stronger than 28.2e, i get locked on 26.e but im trying to get 28.2, if 28.2 is stronger then i might be on 28.2. Have not checked on sat box as i was busy. What is the quickest way to get 28.2 im using a first strike meter. Thanks
Ha thanks, i speak fluent spanish. But i will do thatDown approx 0.5 degree, rotate 2 degree East, try using Sky News on 12207 V 27500 as a primary lock.
Need to know where you are to advise the size of dish you will need to get BBC, ITV etc. If deep south, give up and learn Spanish quick!
- What do you mean by "I receive all channels"? Could you specify which channels?I receive all channels in Valencia on a 1.2m without problems except for 11053H (ITV2 HD), which is permanently no signal. Is this due to interference from 11045H on Badr?
Is 11023H also receivable ? Could you post a screenshot?
And how do you know that there is 11045H transponder on Badr? I can not find it on Lyngsat or KOS.
By posting a screenshot I mean to grab picture of the TV-screen and post it here. Something like this View attachment 114145
That what I was asking from you to show similar picture of reception of 11023H with all the data about channel available on the screen.
Have you tried receiving it at 11049H, or at 11057H?
Sometimes with a LOF instability, you (at first) only have problems on one transponder.
That's why I always test that first, with shifted frequencies (or shifted LOFs, that has the same effect).
greetz,
A33
