hi m8s heres my problem im getting from 10 east to 8 west ok but either side of that im dropping out now should i alter dish elavation on dish bracket or elavation on motor bracket or both not sure which
> Motor inclination is set correctly for your Latitude.
> Fixing brackets/pole are plumb.
> Motor is secured on centre of motor shaft when at zero position.
> Adjust dish/motor together around the pole and by dish EL to achieve the best signal on 1W (ref sat).
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
