BombedOne said:Yes, but certain satellites broadcast only in one band and one polarisation. For example, I've used to connect 80E and 75E via that switch.
In this case you need a relay unit for 2 LNBs and one receiver. The existence or not of 22KHz is used in order to selext LNB (east/west).BombedOne said:Yes, but certain satellites broadcast only in one band and one polarisation. For example, I've used to connect 80E and 75E via that switch.
you do as Channel Hoper says.Huevos said:Are 22khz switches and universal LNBs compatible? If not what does one do when setting up more than 8 LNBs.
