Arris EPG and general niggles
Duncan_H
Mainly Humax 1000S + external HDD
1 off Arris 1TB recordable
1.8m dish + quality quatro LNB to multisplitter
Alicante
I have just got an Arris 1TB dual input receiver.
It's fed from a 1.8m Famaval disk with quatro LNB (specs can be found)
Output is from a German 6 output multisplitter.
The Arris is tested with single LNB1 input.
Last s/w update is 30/3/2023
After total reset the EPG is nowhere near as good as the Humax it is destined to replace, for instance once selecting a program you have to press the 'Home' button to display full screen, etc etc
Is the Arris EPG so bad?
Sensitivity is lower too.
Should I get a 2nd hand Humax dual input box instead?
