iceman
- Apr 3, 2003
- Age
- 64
3.0m Motorised Channel Master + 4 fixed dish Amstrad_DRX890C
DM7020s,DM800se
UNOHM EP314 PROMAX TV Explorer
- Kyrenia - NORTH CYPRUS
Hi Tony
I do not belive any feed horn will give you 2D if your dish is not in perfect geometrical shape...make sure it is......Have you stringed it?
Installing a multi reflector dish of this size requires some level of experience+skill...if a little mistake is done or overseen in assembly stage,dish will not perform at its expected capacity,u might have to dissasemble a few times to get it right...do not give up cos this might hapen to even the most experienced.
One other thing...do not take manufacturers quoted F/D to be %100 correct.
give it a few cm's +/- either way when testing...test your signal from different focal distances to determine best F/D.I prefer to do this on a weak
but receivable transponder.
I belive your 3.8 Patriot is capable of delivering from your location if it was set up accuretly.
iceman
iceman
