Analoguesat said:Up or down?.
Excuse me,this is what I was on about a couple of weks ago. And 10.803 (BBC Scotland).iceman said:Down...there seems to be an overall signal reduction on 10773H,and this is affecting reception,specially at early hours of the morning and early evening.
I can't. Except that with all these people that are having problems, I don't. My only advantage,maybe,is that I live in a south facing semidetached house and the house next to ours is 2 floors higher.And when I installed my dish it ended up pointing up just missing next doors house ,so I guess its blocking a bit of Arabsat.iceman said:I am not yet prepared to accept this Badr interference theory...
I have had reports from some 4.2m dishes experiencing problem with 11773H,BUT i myself use a 3m prime focus Channel Master and have had no problems whatsoever!!
How do you explain that?
Zorba said:My only advantage,maybe,is that I live in a south facing semidetached house and the house next to ours is 2 floors higher.And when I installed my dish it ended up pointing up just missing next doors house ,so I guess its blocking a bit of Arabsat.
Also we don't use Channel master dishes and I wonder if your dish is deeper than our DH dishes. What is your focal length ?
Yes I do because I have a similar problem with my Showtime on my 1m dish which is pointing at next doors house. I have placed it at the front of my roof and next doors balcony is in line of site and I cannot receive OSN movies.iceman said:c'mon man....do you seriously believe your neighbors roof is blocking "a bit of Arabsat?"
Focal distance on my dish is either 121cm or 122cm..not sure
No,because as most people are having problems with BBC, I don't because my dish just clears next doors roof, so I think the roof is just blocking the Arabsat transponder. Remember its only 2.2degrees away from 2D. You can see it on a spectrum analyser. If you look at your analyser while it is on 28.2 and set for 10.773 just start moving the dish to the right and as soon as the 2D starts to fade away up pop 2 transponders on 10.770 and 10730 at twice the strength.cheekymonkey said:I have a 3.7m DH dish in Fuerteventura and have had these exact problems with 10773. Signal fades out from about 1900 ish. Am now using a different BBC region and for BBC2 I end up using BBC2 Scotland. Signal on my technomate shows that 10773 is down by about 5% compared to what it was a month ago. The Badr theory is the best reason I have heard yet but could it not be that the transponders are simply not as good as they were and will get worse with age as 2D enters the end of its life cycle.
