BBC Prime Dreambox problems....maaad
suro
Guys recently I got my dreambox repaired (the 22khz problem, remember?) Now I get almost all the channels except for one which I really want to get, It is BBC Prime which is on 11131MhZ, 5632 Symbol Rate when these setting are entered the signal cannot be locked, I had also another receiver(PremiumX), on that receiver BBC Prime shows perfectly with no signal problems. So how can this happen?
I use Dreambox 5620 with the latest Gemini Image satellite dish pointed to Hotbird 13E
A have almost the same problem with 5620 and Gemini 2.7.
It locks the channel, but the picture and audio quality is very poor.
With Gemini 2.1 I have no problem. Try other image.
I do not now what causes it.
I don't know why you want to watch this perticular frequency, I can see BBC Prime without any problems on all images using 10756 Vert 3/4 27500
Why don't you try this and also let me know why you need the other freq.
TG
I also found another one on 11129 V 3/4 05632, that one also a very strong signal
TG
Hi T_G,
This BBC Prime is in the TPS package. There are rumors that TPS changes to Via 2.6 on March 10th. Bye-bye TPS.
I also have quality problems with the low symbolrate channel. DreamMultimedia told me the sensitivity problem of DM 5620 could not be repaired.
Regards
Paul_HU
Hey guys, after testing on two dreamboxes and two dishes with various setups, i have found that gemini 2.7 is the problem. It doesnt like quite a few chans, especially bbc prime. Especially when used with an emu. Roll back to a previous gemini version for the fix.
From my tests i have found these images have the best results on these boxes
DM7000/7020 = gemini <2.7 (not 2.7)
DM500 = pli
Guys,
The main problem is not the bad tuner. I have tried some old images based on cvs 106 and all worked with strong low symbolrate channels. The lowest SR was below 3000ksym/sec on Eutelsat W2 16E, called Alsat TV 10957 H, SR:2821, FEC:2/3.
We should tell the developers to consider putting back the old tuner driver in the new developments.
Paul_HU
