BDP 115 to load Nokia9200.HELP!!!!
Zebo
hello everyone. could anyone help me to load a Nokia mediamaster 9200 with DVB2000.ive got both Transbox and BDP 115 but everyone says its better to use the BDP115. could anyone tell me where i can get the manual for this loader cos on the web sites it says i must use zero modem cable while starting the loader and trying to choose the right COM port it gives me to choose among LPT ports.and generally any help on how to use this BDP115 loader would be appreciated. i really need this one. thanx in advance
BDP115 is used with a BDM interface not a Null Modem serial cable. The BDM is connected to a parallel port (25 pin), also known as a LPT port.
This is a big subject, if you are serious about this there are a lot of people here who can help.
But first I note you have a 9200. A lot of these have B200uns bootloaders already loaded so you probably won't need a BDM. The first thing is to check your bootloader - what does it say when you plug it in. The green display will flash with B2.00uns or something else for a micro second.
i know, ive already checked the bootloader and it doesnt need a BDM cos its B200uns. i just need the procedure of operating the BDP115 and loading DVB2000.so how do i configure the ports, since im not gonna use the BDM. it says i need a null modem cable while in the BDP115 i can only choose among LPT ports.
If you have B200uns bootloader you should be able to load any version of DVB2000 with a null modem serial cable.
BDP115 is not used for this purpose. There are many different software programs that can load DVB2000 with a null modem serial cable, one is DVBedit.
You can get DVBedit from this site _www.coolstf.com/dvbedit/index.html
