Begginer with Diablo Cam light
kellyJR
PACE DS810X
80CM DISH
MOTORISED
HUDDERSFIELD YORKSHIRE
Hi
I have just recieved my new Diablo light card, but find my free to air stations will not work when the card is in place and whats more the card does not unscrabble the sports premier channel on astra 1. I left the card in all afternoon but no joy.
I am using a pace DS810XE which does recognise the card.
Any clues?
Cheers
Kellyjr
What card??? Or is that a misprint for Cam?
Have you loaded underworld 132 and turned both N2 AU and Emulators on in the Configuration menu?
Have you got a Cas programmer?
Yes sorry i mean cam
I think the problem is i need to upgrade the software on the pace box to
1.0.35 so am busy re setting the box and will try to download the new version. Never watched so little tele in all my life, but will get their.
The learning curve is pretty steep for this lot.
Thanks for the promt advice again
Yup software now download and going well.
Cheers
Kellyjr
Hi
Download the new software, but the cam is still not working and blocks all other channels. Underworld 132 is loaded and both N2 AU and Emulators on in the Configuration menu?
Any ideas?
Cheers
Kellyjr
There have been problems getting cams to function correctly by the Pace DX10XE since it came out.
Check the Pace HD section in this forum, particularly the sticky. Maybe a later software update may help.
Currently running 1.0.35, i shall check the other posts.
Cheers
Kellyjr
Hello,
i do not succeed to program one diablo light cam 2.3 with cas interface 3 plus
studio 8.7 for underworld 1.80
the studio write "not enough space" when the cam is empty.
I do not know where to find the genuine firm underworld, perharps this that I have is wrong. where to find underworld 1.80 ?
Hello,
I have heard of this problem before when the Underworld file has not been uncompressed.
Most files require Winrar, or winzip, to uncompress them, then you load underworld180.dup, although there are newer underworld files, the last being underworld 187.
