stuzeeuk
Dont eat yellow snow
- Triax 88, mulitblock
13E, 19E, 28E
DM 800HD
- Glasgow, Scotland
Can anyone recommend some good coax cable for fringe reception ?
I bought some at the local market (always and mistake !) and its cr@#p .....
Its locally made and obviously poor quality. I have tested different sat receivers, switched LNB's and re-run fresh cable twice. I can only assume its the poor quality of the cable itself.
I'm getting 20% less signal in the living room with the new cable as I am in the downstairs bedroom (using an old cable). Also Some of the channels like Bloomberg and TPS as just breaking up despite 40% & 70% signal strength.
Grateful for some suggested decent suppliers ....
