Advice Needed Best grease for AV equipment
davemurgtroyd
Oxford
Oxford
What is the best grease to use when regreasing metal and plastic mechanical items in AV equipment - drive trays, tape mechanisms etc? Also what is the best way to remove old solidified grease?
skomedal
This and that
thule
"" Nail varnish remover should do the job for removing solidified grease ""
Read acetone, much cheaper:D
Edit
Avoid plastic parts which disolve :eek:
davemurgtroyd
Oxford
Oxford
Edit
The problem is most of the parts are mainly plastic
blademedia
Sky
Edit
I've used this for years, it the best thing to use on nylon cogs with stubborn solidified grease, there is different strengths, if you use nail varnish remover as I mentioned before, it will be fine its a really diluted version.
davemurgtroyd
Oxford
Oxford
Plastic or nylon????
Have read plastic from #1
Regards
Both nylon and plastic. Rollers and gears usually nylon while guide tracks ("geared" and plain) and levers are plastic.
Terryl
Custom built PC
Dont use nail polish or acetone on any plastic parts, nylon is OK, but the plastic will melt, one big mess.
I would use denatured alcohol and an old toothbrush.
