Best Satellite Box for Strong Tuner
Pauliewalnuts
Three Sats Optus D1,D2 and Intelsat19
Melbourne Australia
Can i please get some reccomendations on what receiver to buy for a quality tuner with strong signal, i have a GT media Combo box atm and it's great for autobiss etc but it struggles with signal strength on some feeds. TIA Paulie
P.s - I live in AUS and have three satellites on my roof, 2 x 1.2m
You aren't going to find another receiver that is significantly more sensitive than the one you already have.
For more signal increase your dish size.
Pauliewalnuts
Melbourne Australia
Incorrect, my mate has a Strong Receiver and a GT Combo and that's how i know he plugged his antenna into the Strong receiver and got a much better signal so that's why i was asking cause that receiver is now obsolete
You already have the answer then.
Pauliewalnuts
Melbourne Australia
No that was my question what box has a very strong tuner, the Strong receiver is now obselete
Was the Strong receiver able to receive signals the GTCombo couldn't or were you comparing percentages? If one type of receiver displays a higher percentage figure than another it doesn't necessarily mean it has a better tuner.
jojoz
Emme Esse 115 Alu satellite dish
Stab HH120 diseqc motor
Golden Media High Gain Quad LNB 204+
Octagon SF8008 single satellie receiver
Athens Greece
Every satellite receiver has its own signal measurements. You can't say that Strong receiver is better than GT combo. It's true that some receivers have a more sensitive tuner than others e.g. you can get signal in some frequencies or feeds. The lnb is another factor. But as william-1 says a larger dish makes the difference.
Pauliewalnuts
Melbourne Australia
The feed was on Optus D1, the GT Combo signal quality was poor and dropping out, as soon as you removed the antenna and plugged into the Strong receiver the signal was very good, same dishes etc being used different receivers
If you can provide the model number somebody on here should know which tuner / demodulator are contained within.
The software that governs how the circuit works will also have an impact on how efficient the front end is.
Pauliewalnuts
Melbourne Australia
The menu structures in the manual are very similar in design to a Technomate satellite receiver.
If I had to guess, I would say the Strong receiver is probably a different branded version of a Technomate TM-5402 (M1) model as the rear panel layouts are also similar.
Pauliewalnuts
Melbourne Australia
Thanks Moonbase, any idea where i purchase that model, does it have biss? Doesn't have to be autobiss just the feature where i can manually enter the codes.
Pauliewalnuts
Melbourne Australia
Looks hard to get for Australia, any other recommendations
Manikm909
Small'ish Dish Man
Kent, UK
dishes? you mean dish i hope.
my GT combo is the same as my octagon SF8008 - both VERY good tuners, you'll be hard pressed to find better.
let me know if you find one, might sort out my ESPN issue.
Manikm909
Small'ish Dish Man
Kent, UK
i tried the TM5402-M4 today on 40.5w - ESPN, beleive it or not, the STB does give a slightly better signal than the octagon sf8008 \ edision mIo 4k and the GT MEdia combo....
the breakup is much less frequent, and its more of a smoother breakup if that makes sense, its more of a pixel blur than a full picture gone and and return type scenario. (this is when signal gets down to 8.0db)
