Best satellite dish 2019
J
jaaa1976
vu uno 4k se, mutant hd51
Norfolk
Hello..I want buy new dish and want ask which make is best now.. I will be using astra 23.5 and UPC direct 1 west.
I want buy best quality and not too heavy.Also which size will be enough here in UK NORFOLK.I have triax TD 115cm big ..but arm is broken now and is too heavy. Receiver VU UNO 4K SE .. thx
M
2.0m Precision
If you want a reasonable quality dish that is not too heavy you could consider a Gibertini 1.25m dish or a Gibertini 1.5m dish. The relector is made of aluminium and Gibertini are a popular choice.
J
jaaa1976
Norfolk
If you want a reasonable quality dish that is not too heavy you could consider a Gibertine 1.25m dish or a Gibertini 1.5m dish. The relector is made of aluminium and Gibertini are a popular choice.
Ok..dont want too big..will 90 cm will be enought?
The UPC transmissions can be received on a good 90cm dish, but best to go to the maximum limits of planning permission to cover really bad weather.
J
jaaa1976
Norfolk
ok..will aluminium dish will be better like mesh? or which is best type dish in 2019?
Unless you are in a really windy location (inward sea conditions) stay away from a mesh dish.
for the same locations, stick with aluminium if you can, but make sure it is not damaged when it arrives, ask for the signals from the installer once installed.
edbe
edbe
Dreambox 7020HD - GigaBlue X3 - Sky Q box
Wavefield T55 - Stab100 with Triax 78cm
Ziggo - Tv Vlaanderen - Sky Ireland - HD+
Kerkrade, Holland
Triax 88 or 110 is a good dishes
Tout Rond Bon Oeuf
OP Gibertini 100 XP+ Inverto Black Ultra 0.2
(50 east to 34.5 west)
TM6902HD (A/B switch) Octagon SX88+Optima
Raven 88cm Mesh Dish + TM-1 0.1
Octagon SX88+ (A/B switch) Edision S2
45cm dish V8 Golden 28E FreeSat Quad Lnb
Virgin Media FreeSat
Archive9
Archive9
Archived
Sky Dish for the moment.
South Somerset
Four would be even better:rolleyes:
Better still give up with the triax and fit a gib or techno mate :-wow
If you really must fit a triax keep the duct tape handy as your hands will need it.
Just my opinion, why do triax insist on the pole mounting bracket at the bottom of the dish:confused as a good gust of wind and the triax will wobble about on and off signal.
Just my opinion.
Just my opinion.
Good point - although I don't have much trouble with the dishes here wobbling as both the TD88 & TD110 are on ground-mounted poles "stabilished" to the adjacent (neighbour's - but they don't know that!:) ) high fence and thus are well protected from any real wind effects
OTOH, the LNB arms can (like many dishes) can still wobble even then - but I fit a couple of "springy" steel strips (from B&Q - used for connecting roof trusses and the like) from just in front of the LNB holder (with a car exhaust clamp) to the edges of the dish and that solves that issue as the arm is then "rock solid" w.r.t. the dish
sonnetpete
sonnetpete
Grumpy Old Moderator
Normandy, France
Will the dish be used for multisat (i.e. more than one LNb or motorised?
sonic1
sonic1
Vu + Ultimo 4K - Solo 4K - Uno 4K - Duo2- SoloSE - Zero- Uno -Prismcube Open Black Hole - 0.6 , 98cm Funkee , 28E-23.5E-19E-13E
Black Hole Team
Just my opinion.
Why the gloves ? I am curious :cool:
I suspect that @Chris1979 finds the edges of heavy dishes (and the TRIAX ones are heavy) very uncomfortable without them, as do I, but I manage without them because I usually need to hold a small spanner to tighten/loosen the bolts during the adjustment process and gloves make that a lot more difficult.
Archive9
Archive9
Archived
South Somerset
The edge of the dish/mounting assembly can and will given half a chance slice into the palms of your hands or leg.
8 foot fence now fitted behind my pole ground mounted dishes to protect them from the wind :)
J
jaaa1976
Norfolk
Hi..just 1LNb with 2 outputs and only 1 satellite .. astra or thor.
