Right spent all day checking. Not easy as one would think. Obviously have to measure to make sure dish is positioned on roof so it can point towards satellite. I worked out centre point of pole. Then measured to depth of bottom of dish (where it sticks out due to bracket, tilt and curve of dish). Then got small dish out and aligned to satellite, marked on roof straight line along lnb arm. Measured to where left hand of dish would come, allowed for curvature of dish. Placed small dish there aligned and again marked straight line on roof along lnb arm, couldn’t do same with right hand side as dish will stick 65cm over side. I then measured from the left, middle and (guessed) right side following the drawn lines to neighbors’ wall. Each measure was different due to the angle of the dish to house and the fact that the wall itself is staggered. I then had to allow for other additions such as pitched roofs (setback from wall), a chimney, another dish and a stairwell wall. I used the calculator Iceman mentioned and calculated for each part of dish whether it would clear the corresponding obstacle. It looks like I am going to be lucky and it will just work (outside chance of part of the chimney blocking extreme right of dish).
So going ahead, have ordered new bolts for dish and 2100kg of concrete and reinforcing for my 215cmx135cmx40cm base. And an RSJ to add support in the roof.
Will take pictures of work and post when done.
