taken from blade site
* DVB-S2 Satellite Compliant ( MPEG-4/ H.264)
* Output: 576p & 576i, 720p, 1080i & 1080p
* 1 Smart Card Reader & 1 Common Interfaces (2CI)
* HDMI & Component Output (YPbPr) with Upscaler to Improve Picture Quality
* 10,000 TV & Radio Channels
* USB2.0 PVR Ready via external HDD or USB Flash Drive (memory stick) with Time shift, Record & Playback functions
* MP3 player and JPEG viewer via external HDD or USB Flash Drive (memory stick)
* Software & Channel List download via USB 2.0
* Blue Glow Front Panel Display
* Sensitive Tuner
* Less than 1 second channel change
* Dolby Digital Optical S/PDIF
* DiSEqC 1.0, 1.1, 1.2 & 1.3 (USALS) compatible
* Auto Navigation system – select as many satellites as you want to search
* On-screen display with true full color resolution
* Enhanced 16 Favorite channel groups
* Channel control by: Favorites, Lock, Skip, Move & Delete
* Channel sort by: All, Alphabet, Transponder & CAS
* Multilingual OSD Menu: English, Spanish, Portuguese, French, Dutch, German, Italian, Turkish, Arabic, Russian, Persian
* Extended EPG and program reservation on EPG
* Teletext & Subtitle by OSD and VBI
* Last channel memory function
* Factory default channel list
* Various games
* Software & channel list upgrade via RS-232C: PC to STB, STB to PC, STB-STB and USB
* Parental, Installation & Receiver Lock
* Zoom function on Pause & Live channel
* Multi picture display
* Support for multiple language broadcasts
* SCPC & MCPC receivable from C/Ku band satellites LNBs supported: Universal, Single, Single S & C band wideband LNBs
* Multi TV Standards supported: PAL G, I, K, M
* 4:3 & 16:9 Screen Formats
* 90-250V AC 50/60 Hz
* LNB Short Circuit protection onboard
* 2 Scarts & S-Video and LAN port
* Dimension 390x272x70 mm
Technical Info
* TUNER & CHANNEL Satellite Input connector F-type, IEC 169-24, female
* Loop through connector F-type, IEC 169-24, female
* Frequency range 950 MHz ~ 2150 MHz
* Input impedance 75Ω unbalance
* Signal level -25 to -69dBm
* LNB power & Polarization 14V/18.5V, Max. 400mA
* 22 KHz tone (22±2)KHz, (0.6±0.2)V
* DISEqC control Version 1.0 &1.2 Compatible, USALS
* Demodulation QPSK, 8PSK
* Input symbol rate DVB-S: 1 ~ 45 Ms/sDVB-S2: 10 ~ 30Msps (QPSK,8PSK)
* FEC decode DVB-S: 1/2, 2/3, 3/4, 5/6 and 7/8DVB-S2:1/2, 3/5, 2/3, 3/4, 4/5, 5/6, 8/9, 9/10 (QPSK).3/5, 2/3, 3/4, 5/6, 8/9, 9/10 (8PSK)
* MPEG Transport Stream & A/V Decoding Transport stream MPEG-II ISO/IEC 13818
* Profile level MPEG-II MP@ML, MPEG-IIMP@HL, MPEG-IV AVC/ H.264 HP@L4.0
* Input rate Max. 15Mbit/s
* Video formats 4:3 Letterbox, 4:3 Pan & Scan, 16:9
* Video resolution 720 x 576, 720 x 480, 1920 x 1080i, 1280 x 720Pm and 1080p Full HD
* Audio decoding MPEG/ Musicam Layer Ⅰ&Ⅱ
* Audio mode Stereo/ Joint stereo/ Mono
* Sampling rate 32KHz, 44.1KHz and 48KHz
* Main System Main processor 32 bit super scalar RISC CPU
* Memory Flash-Rom: 64MbitDDR DRAM: 512MbitEEPROM: 256Kbit
* Conditional Access Interface PCMCIA 2 Slot (DVB Common Interface Standard)
* Smart Card Reader 1 Slot (HTM 8000 HD+ only)
* A/V In/Out TV SCART Video output (CVBS,RG
· Audio output (L,R)
* VCR SCART A/V output (CVBS, L/R)A/V input (CVBS, RGB, L/R)
* Video RCA/ Cinch, Video output (CVBS)Component output (YPbPr)HDMI (High Definition Multimedia Interface)S-Video
* Audio L/R RCA/ Cinch, Volume and Mute control
* S/PDIF Optical digital audio output
* Data Port RS-232C Transfer rate 115Kbps, 9 pin D-sub type
* USB USB 2.0 Host(Support 1 USB Port on Front Panel )
* LAN Port for connecting to the internet
* Power Supply Input voltage AC100-250V, 50/60Hz
* Type SMPS (Switching Mode Power Supply)
* Power consumption Max. 55W
* Protection Separate Internal Fuse (The input have lightning protection)
* General Data Dimensions (W x D x H) 335 x 247 x 58.5 mm
* Weight ca 3,500 g
* Operating temperature 0°C ~ +45°C
* Storage temperature -10°C ~ +70°C
