2 Dreamboxes..........
--- DM 8000 HD PVR & DM 800 HD ---
Motek SG2100 & Triax 80cm Dual LNB
------ Fixed Dish 28e Quad LNB -------
---- Sly HD Full & 24" Apple iMAC ----
I highly recommend you use the Dreambox Config Creator. It uses later code for the boxkey conversion and renders the Box Key converter out of date. Click the link in my Sig to get it.
thanks ive got tht nw i got my box key aswell but whr do i put the box key into the cccam.cfg and feq i been told aswell here my email live messenger [Moderation] Email removed.
i read it and tryed it nuffin anit coming up on my screen im send my cfg and u will understand whr i gone wrong
# This File Was Created Using NewCS / CCcam Config Creator
# Designed & Written By B16MCC. 2009.
SERVER LISTEN PORT : 80
BOXKEY: /dev/sci0 xx xx xx xx
PINCODE: /dev/sci0 xxxx
x means not showing the realy info
N: my ip 15000 CCcam CCcam 01 02 03 04 05 06 07 08 09 10 11 12 13 14
F: test test1 0 0 0 { 0:0:1 }
Dude, for christ sake speak english ! It's so annoying trying to read garbage text speak.
Give us more info. Are you connecting to someone elses card, or using your own in your box ?
Having installed CCCam and setup your config, have you actually started CCcam ?
Chinywhite - please post in proper English - many of our members are older folk and cant read the garbage txtspk. If they cant read yoiur posts then you wont get the advantage of their years of experience.
And to be honest its bloody annoying to read I work in a school so I can read much of it, but if you wont post in proper English I cant be bothered to help.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
