Boxnation not working on Vu+Duo
JonRDS2484
Astra 2 and windows xp
Spain
I have a vu + Duo with a full Sky Uk pack and I have just added Racing UK and Boxnation. Racing UK is working fine but I cannot watch Boxnation on it. It is working fine on the Sky box but not on my Vu+ Duo. Can anybody help?????
needs to be read with oscam bud.
Thanks for the replies, I now have OScam/CCcam 2.1.3 installed on my vu+ Duo, But I´m still struggling to get it to read my card. I have located /etc/tuxbox/config and put my box id in oscam.server, Is there anything else I have to do to get it to read my card? OScam is totally new to me so I am a bit lost at the moment
You dont need the boxkey in for Oscam it reads the card automatically, you would be better trying to find some working configs for your duo have a look on the Oscam board plenty on there.
I have found working configs and FTP'd them over to my Vu+ duo. The card is now working but it won´t open boxnation or any premium channels for that matter. Could it be that I need a newer version of OScam or maybe keep lookin for more configs to try?
What version of oscam do you have running at the moment as you can download the latest Mips version and replace it with your version in the /usr/bin file
Captain Jack said:
Was pretty sure you needed a box key but maybe that's only for CCcam...
Hi CJ
Not with Oscam it reads the Card no problem
OP your running a pretty old version of Oscam get hold of the latest Mips version and over write where i pointed to.
I have tried numerous versions of OScam and configs for Sly uk but I am still unable to get boxnation or any other premium channel for that matter (only sly1,discovery etc). I have followed tutorials on setting up a sly card for oscam and I can't see where I am going wrong. i have even tried putting in the box id which I have been told is not needed but it makes no difference. I am currently running OScam6338+cccam 2.1.3 for blackhole. please help me!!!!!!!
have you got the configs right in Oscam for the 0963 card and also with that combination you need to give yourself an N: line in CCcam as Oscam is only reading the entitlements of the card, If you still cant get it to work uninstall oscam+cccam and get hold of Oscam o its own just to act as reader for the Duo. Latest versions can be had through TSpanel
Hi Digi, here are my configs
oscam.server
[reader]
label = slot1
protocol = internal
device = /dev/sci0
boxid = *******
blockemm-u = 0
blockemm-s = 0
blockemm-g = 1
blockemm-unknown = 1
emmcache = 1,3,2
group = 1
caid = 0963
oscam.conf
[global]
nice = -1
WaitForCards = 1
logfile = stdout
preferlocalcards = 1
saveinithistory = 1
[newcamd]
key = 0102030405060708091011121314256
port = 10000@0963:000000;10001@0963:000000
[webif]
httpport = 16002
httpuser = root
httppwd = xxx
httprefresh = 10
httpallowed = 127.0.0.1,192.168.0.0-192.168.255.255
oscam.user
[account]
user = JON
pwd = RDS
monlevel = 0
uniq = 0
group = 1,2
au = 1
caid = 0963
and my N line in cccam.cfg is
N: 127.0.0.1 10000 JON RDS 01 02 03 04 05 06 07 08 09 10 11 12 13 14 256
can you see any problems?
I'm using the same version of Oscam as mentioned in a Dreambox, but without Cccam and with DVBAPI in Oscam.config. Works OK with Racing UK.
JonRDS2484 said:
[newcamd]
key = 0102030405060708091011121314 256
The 256 should not be included in the key.
You should only use one port per CAID.
ie
