Bying a dish
G
Gladiator8387
Likes
CypRuS
#1
I ordered 1,80m dish.. and they told me that is offset..
What's offset?.. What's the difference?.. Is signal weaker?
Likes
1,291
#2
No, should perform pretty much as well as a prime focus dish, the only difference is that the LNB looks at the dish from an angle below the centre.
gameboy
gameboy
Ding Dang Doo
Likes
5
Scotland
#3
G
Gladiator8387
Likes
CypRuS
#4
thnx.. well my worries are whether i can attach a motor on my offset dish in the future? is that possible?..
gameboy
gameboy
Ding Dang Doo
Likes
5
Scotland
#5
No problem. A motor is fitted behind the dish and the most popular is the DiSEqC type.
Rolfw posted a great picture of one with an offset dish attached a few days back - if he's online he may remember the link to the picture and post it.
Edited..
Found thread here - post Number 10 but other dishes also have DiSEqC motors.
http://www.satellites.co.uk/php-bin/forum/showthread.php?t=28389
G
Gladiator8387
Likes
CypRuS
#6
Emm... My dish now (1m) have two lnb's.. one located at astra and one at hotbird.. can i attach one of this lnbs on the 1,80m that I would buy?
I think LNB is 0,3
gameboy
gameboy
Ding Dang Doo
Likes
5
Scotland
#7
Yes, if it is a universal type (most are).
Lancelot
Lancelot
Retired Mod
Likes
SS1.
36v H to H 62E - 61.5W
South central
#8
You may want to think about something quite robust to turn a 180cm lump
dont know if any DiSEqC 's are up to it.
G
Gladiator8387
Likes
CypRuS
#9
So..ur advice is not to use a diseqc..
What shall i do do u believe? To buy a motor?
gameboy
gameboy
Ding Dang Doo
Likes
5
Scotland
#10
1.2m is maximum size for a DiSEqC motor.
You will need a 36v motor which will also need another cable to the dish ( the DiSEqC uses the same cable - low voltage)
You will find plenty of info on 36v motors here - do a search.
