I'm soon to be installing a dish - and need to run cable down to the decoder of course, but already have RF cable chased into the wall for the television. To make a neater job I'm wondering if it is possible to somehow join the cable which runs from my aerial to the new cable running from the dish. I would then have just the one cable running down - albeit hosting two signals.
At the socket end behind the television I could then splice the cable into two outputs, one for the RF input to the TV, and one into the satellite decoder. I appreciate the cables feed up to the satellite dish carries a low voltage to the LNB (cannot remember what this is.....9/12v?) but surely this should still work give that each signal is at a different frequency....... or am I getting out of my depth?
It does not seem common or 'accepted practice' in the UK but I'm sure I've seen this done in for example in France especially in new houses where the existing cable is behind say plasterboard - and as said, it would certainly make a neater job.
Cheers.
Cheers.
