Camo antenna from cat tunnel...
zorrin
Specialised contributor
CM 120 Ku 52°E to 45°O
CM 120 Ku 50°E to 45°O
CM 120 Ku SDR 25.8°E
CM 100 Ku 5°W
CM 100 Ku 9°E
CM 90 Ku
Visiosat Bisat Ku
Visiosat 70 Ku
Selfsat 2x Ku
Selfsat 2x Ku
Octagon SF8008
GTMedia V8 Nova, V8X, V8 UHD 4K, V9 Prime
Edision Piccollo
france
Because i don't have the right to put a dish, i find a solution from a cat tunnel to hide it... :ph34r::ph34r:
This is my dish, a flat Selfsat antenna with a Selfsat DiSEqC motor.
This is the tunnel for cat, only 1.49euro and i need 3 of them.
From outside my white dish is really visible.
Ok , now let start to camo it !
The first tunnel is used without any modification.
The 2 other are used without metal cable inside.
On the picture you can see some white cable ties but i will change them by something black.
Now from outside the flat dish don't really look like a prohibited antenna isn't it ?
Have a good day ! ;)
Well done for ingenuity, bit strictly speaking, it's not a dish in the first place (even in native french)
Love it.
Most of us get concerned about spiders getting into our LNBs, but you seem to need to worry about nesting cats!
Yes it's not a dish even in french Channel Hopper but i still like to using this word for my new flat antenna in french and in english. ;)
Love it!
And there was me thinking "cat tunnel" was some kind of technical term I hadn't heard of.
Great job, well thought out.
At least you won't get inspectors looking for dishes but you may get an armed swat team:-doh
