cams for offical cards
W
wod
Likes
235
yorkshire
#1
i'm looking to get a cam, well will need one as i shall be getting digitalb card soon but i've only got one card slot in my tm 1500ci+ which has art sports card in it
so will need a cam but do i buy an official viaccess or conax cam so i can use which ever card in the slot and the other in the cam
or shall i get a diablo/t-rex supermodule cam instead if they work with official cards because of the obivous features of them ?
thanks
wod
CROSSBONES
CROSSBONES
Likes
190
S.Wales
#2
The t-rex cam is rumored to be getting a nice surprise soon. Not sure what.
but if you just want a viaccess cam, that is the cheaper option.
sourced from Steave at Waferworld.
W
wod
Likes
235
yorkshire
#3
whats the surprise ? doing nova instead of the gamma card ?
taking of viaccess cam, theres red ones and black version i take it both will work with art card ?
asking an ebay seller and he says that the red viaccess cam wont decrypt art is that true as i thought any viaccess cam would work ?
think i'll wait and see what happens with the t-rex supermodule cam as i forgot i would need a cas 3 to program it
CROSSBONES
CROSSBONES
Likes
190
S.Wales
#4
Not sure what the surprise is. The black cam is Viaccess 1 and tps crypt only.
It can also be flashed to conax and I think crypto.
The red cam is viaccess 1 & 2. This cam can also be flashed to an aston v1.5 or an Irdeto 2 cam.
So you will require a red cam. Or get a black and flash it to conax.
Cant you use a fun 7 card to flash the t-rex cam?
W
wod
Likes
235
yorkshire
#5
thanks so the viaccess red cam will work, liar ebay seller
well if i do get a t-rex cam i will need to buy aswell the cas3 or a card programmer as i dont have one atm and haven't used one since i had ondigital with elvis programmer so i dont have any idea about them
CROSSBONES
CROSSBONES
Likes
190
S.Wales
#6
Yes a red cam should work fine. Do you still have the elvis? As this is a great programmer. You will just need a dragon loader card to programme it. or a fun 7 card.;)
W
wod
Likes
235
yorkshire
#7
nope i got rid of it after ondigital closed down
what card programmers are recommended to program the cam then as if a card programmer is cheaper i might get a trex supermodule cam and one as the cas 3 plus is like 55 quid
CROSSBONES
CROSSBONES
Likes
190
S.Wales
#8
all these work great
Elvis, serial and usb.
Cas 2 & 3.
Infinity Pheonix USB
Dynamite.
Vxmulti 2 pro.
You should pick up a cheap elvis on ebay, as these do most cards.
