Oily
- Satellite=Motorized Triax 88cm&a DM800HD with 500gb hd.Vu+ Duo
- Radcliffe
After having major issues trying to get my 500gb USB(external powered) hd to work with the DM i took the direct route!
I opened up the enclosure of the hd,took the hd off it mounts and unplugged it from the pcb.
I plugged in the sata/power cable you get with the DM into the hd,put the hd back in its enclosure,plugged it onto the DM like this(see photo)and it doesn't work?
I'm guessing it doesn't have the guts to power a 3.5" unless i've done something wrong ?
