GreenmanBelg
- 1 x CM 1.2m matching C120 feedhorn and Invacom 0.3db twin output LNB.50 degrees East to 42 degrees West.1 x CM 1.2m AZ/EL mount matching C120 feedhorn and twin output Invacom 0.3db
Humax VACI 5300
Old Panasonic Digibox
with IRL $ky sub. Coship FTA
- 40kms NE of Antwerp,Belgium.
I should know this but the need never arose before. Bought the Smart MX 4 L this week for feeds etc, its fine for that but I would like to use my Topfield as well I like the Topfields software. The Topfield will be the main receiver so dose that mean the Topfield is antenna in and the Smart is feed from the Topfield?
If the Topfield is on and I switch off the Smart I see the Topfield and visa versa?
Thanks in advance.
Thanks in advance.
