Hopefully someone can help as I cannot find my manual for my Panasonic
TU DSB30.
My Brother in law has just purchesed the same unit so he can watch UK Sky programmes in Sweden, however this is the problem.
Can I check the unit is working before shipping it to Sweden.
When I connect it to my dish and insert my card it comes up with a problem for the card. Does this mean that you can only use one card in one box or is there a way that I can register the card into this box just so I can see it does work?
I suspect this is in the manual
Will I have to do the same again when I transfer back to my box?
Hopefully I have put in the correct forum area
thanks
TU DSB30.
thanks
