CCcam Problem
arrow
help on
gr
Hello. I've got a Dm7020s a Sifteam firmware and a BIG problem. My problem is I can't find CCcam so I download. Tried manual add CCcam.cfg on var/etc 755 but after rebooting my Dm I could only see Common Interface and NOT CCCam. Please Helpme.
Thank you in advance.
Harry.
Harry.
Here is the cam needed using a ftp program send it to tmp folder and use the 7020 to install the cam so you can configure the .cfg file
@ttp://www.sat-universe.com/showthread.php?t=146923&page=2
Thankyou for your reply. I went where you said and I downloaded the cccam file. Now new question and I beleve last:
I unziped the file VAR but I've seen more ZIPED files inside.
What sall I do?
Do I unzip all ziped files OR I put the VAR file as I downloaded in tmp folder and use the 7020 to install the cam so I can configure the .cfg file?
Thankyou again for all your help.
Harry.
Thanks for your reply but these file is ONLY 1kb. Is that all or I'm missing something?.
Harry.
All the file does is tell the image the URL of the download file.
Its only a url which is why its only 1k. :D
There should be a txt file in with it which tells you where to ftp the file to in the image.
Nano
A very very big thankyou for all your help.
Folowing your instractions now i have sifteam +++++++ cccam.
Thankyou again and again.
Excellent news - I've not gone for Linux boxes so far and keep putting it off, but the help available is second to none.
