challenging problem
RedDevil_UK
Retired Mod
Dreambox 7000S, VU+ Solo2, 1.1m Dish, Moteck SG-2100A DISEQC Motor
Rochdale
i use i program called Xbox connect, on my pc that connects an xbox online.... or 4 in my case :)
the home network i have is wireless (Router and bridge) and 1 PC, 2 laptops and 3 of the xboxes work fine.
but the Xbox in the living room, no matter what i do will not join the other xboxes in a game link???
to simplify this ill pretend these are 2 PCs in the same house, playing online gaming sharing an internet connection... but they both cant join the same game ie when 1 PC is in the game, the other cant join?
maybe this is because Hosting servers wont let 2 connections with the same IP join??
so what the best way round this? is there a way to get one PC to somehow change its online IP somehow?
i dont know if all that makes sense.
Surely if your router has its DHCP server ticked then the IP's will be issued by the router sequentially and therefore there will be no conflict
correct... Locally, but the IP seen online is the one issued by my internet service provider, and it cant be changed :(
what i was hoping was that it could be masked, by some sort of proxy, so that when the two computers meet online, the Host thinks they are from different sources... not the same address. Therefor granting access and allowing us to play each other
its complicated lol
can you not set up a free isp, then in the connection settings (is it interet options) set it to your usual connection as default, ihave arrdvarrk (smartemil) using mozilla and a*l broadband, and i think they would appear diff even from same comp (if that makes sence):)
