Channel Hopping Help
Blatherskite
Sky+ HD box (basic package)
DM800HD
Geotrack polar mount
88cm Triax dish
Geordieland
I have a digital receiver and tv in an upstairs room that is also connected to a tv downstairs (via coax), is there a way I can change channels on the upstairs receiver when viewing downstairs without having to go upstairs to do it? Hope this makes sense? Any "sensible" answers appreciated.
Artist 2004
Anatolia correspondent
GoldMaster 7400 CIM 2MB with Kaon board 12.03.a5. Technomate 1000, Technomate 5200 USB.
Two 80cm offset dishes.
West coast, Turkey
Blatherskite
DM800HD
88cm Triax dish
Geordieland
Have looked at both sites, the av sender from Argos at £24.99 was the cheapest. I noticed a Sky Magic Eye remote sender for around a tenner would this do the job and work with a none Sky receiver?
Thanks for the posts
Someone called ?
A Sky sender will not do nada for any other piece of kit, even though Maplins and other outlets promise they will.
I take it the Echostar is more important for the two rooms ? You may get more satisfaction from a 2.4 GHz wireless system which has a return for the remote function. You could also use it for the BSkyB box, but you will have to change the SCART connection before going to bed.
With one of these you can transmit the programme content in stereo up to about 20m if its a decent one.
Burnham Beech
Have a look at the Omni Link+ at B&Q for about £25.
Works through the coax cable like Sky system but will work with any make of remote controlled equipment.
