Channel master 180 dish installation project
dishdx
www.dxing.cz
Showbox Vitamin, Octagon SX88
Dishes: Offset motorised 120 cm 40W-75E IBU Twin, Channel Master 180 78.5E-30W manual rotate , Cahors BigBisat 8 x Alps 1W,5E,9E,13E,19E,23.5E,28.2E,39E. Planty of equipments for FM and AM DX. http://www.dxing.cz
Central Bohemia
Yes, it will be no problem i will measure it. Why do you need it? :-)
RustySpoons
Sleepy Hollow
50E - 30W
2x CM 1.2m Polar Mount/Jack
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
Just seen this pic online .... looks like your feed - and shows a conversion piece
To be honest though i,v found that a standard 40 mm Inverto Black ultra twin l.n.b.f gives the best all round results on my 1.8 offset Channel Master ... and i,v tried many different c-120 type l.n.b,s on my c.m.feed over the years.
That's interesting, is that completely standard or with a modified horn?
Couple of reasons i suppose , to back up any existing database references to mesh size used with this dish and also to gauge what frequencies higher than the normal High Band Ku signals are likely to squeeze through the holes and not reflected back towards the lnb.
I had the same thing when I had my Channel Master, from memory, I think its about a 1.5mm gap.
dishdx
www.dxing.cz
Central Bohemia
Scopus, and how you fixed it? What type of paint? Or do nothing?
Wasn't quite as bad as yours, to be honest I just painted over it. I used some acrylic grey paint, luckily it was a close match.
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
Whats the code/colour of the paint you used? I have the Pantone Code for the CM original colour but it's too expensive to get mixed.
I used Rust-Oleum Winter Grey, from my local Wilko store. Perhaps a litte darker but was fine for me.
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
Ta! I'll check it out :)
archive10
Any repairs are unlikely to improve the performance or longevity of the dish.
My impression is that the steel mesh is stainless, so no further damage done.
But you might want to fix it for aesthetic reasons.
You can use resin-like filler in the form of a car-body repair kit (eg from your local Halford's) to fill in any cavities.
Then sand down, and paint the area.
Or just paint the area to seal it from further deterioration.
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
I've got a tub of P38 for mine :)
I used Rust-Oleum White (RAL 9010) to repaint a Precision dish a few months ago, its decent paint.
archive10
Note that the surface will not be same as the un-sanded areas.
They have this grainy surface (the purpose of which I do not know) made during the moulding.
This will be very difficult to replicate.
But it also has no effect on performance. It's (almost) purely visual.
(My Prodelin dishes do not have this feature...)
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
They probably use it to hide any imperfections that might be visible otherwise considering its construction.
gap30
technomate 90cm dish
Liverpool
A touch of grit/sand in the paint to give the same effect?
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
nelson_b
Contributor
Standard unmodified .. currently around the £20.00 mark on e-bay etcblack ultra twin.jpg
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
Trust
Nijmegen Netherlands
I assume to spread the reflecting of sunlight
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
1.2m dish + Stab HH120
TBS 5925 USB
Octagon SF8008 4k Twin
GTMedia V8 UHD
GTMedia GTcombos x 2
Goldmaster SR525 HD
Sat-illimitè F300 hyper
62.0ºE - 63.0ºW
Alicante, España
Yeah they are great LNB's I have a few IBU's :)
Yes for me as well......the twin is very sensitive......not tested myself but comments are plentiful that it outperforms the quad! :Y
