satkingno
- Vu+ Duo2, Vu+ Solo2, Vu+ SoloSE, Wavefrontier T90 1W-5E-9E-10E-13E-16E-19E-23.5E, Channel Master 1.2m 28.2E 4xEMP Centauri 9/1, 8x Inverto Black Ultra Quad
- Norway
Hi!
I have finally got hold of a Channel Master 180 after searching for quite some time, so pretty happy about that
It has the lightning on the surface, so I guess that means it is actually an Andrews, right?
There is however a couple of small things...
- A small piece of the edge has cracked and come loose. I know that this is purely a cosmetic problem, but still I want the dish to look nice and whole. I was planning to just use some regular fibre glass cloth and polyester to fix this. Then sand it and spray the edge (not touching the surface) with gray acrylic paint. Does that sound like a good plan? Anything I need to watch out for?
Also, it seems a little brittle on the back side, like fibre glass hairs coming loose. Not in large amounts, but enough to irritate the skin and eyes. Guess that's normal after 20 years outside...can I just put on a coat of polyester on the backside? Or should I leave it like it is?
Best Regards
S
Best Regards
S
