blademedia
- Sky
- UK
After having a brief play with the 2,4 DH the H to H has developed a noise, its a easy fix if you can get to the adjustments, unfortunately this is not possible without stripping the dish from the mount and removing a cover on the top of the H to H,
So while the DH is down its a good time to finish the mount and install the 2.4 CM, things wont be happening quick but the install will hopefully be finished before the end of the summer,
I've only really messed with KU band with the DH and taken various readings from around the arc for comparison.
