channel master 2.4m help
icecube
CM 1.8
Kuwait
i have tvro channel master 2.4m, comes with 3 feed legs 2 long ones and one short .
the long ones bolts directly to the antenna, but i don't know where to bolt the short one?
any help please
pictures if possible.
regards
any help please
regards
hi - have a look at this webpage
-http://www.ascs.com.au/products/antennae_and_rf_equipment/skyware_global
there are some PDF datasheets at the right hand side of the page to download - they have pictures in them .
cheers.
Nelson_b , thanks
but the picture is not clear , can any member with CM or andrews take a picture for me?
thanks
there should be a slot for the 3rd lnb arm to slot into.
My cm 1.2 the arms slot into the dish it's self rather than bolt to the sides.
wod,
no slot for the lower arm ,side ones bolts to the sides.
is it possible to drill a hole?
