Cifs Audio Problem
J
jimbo101
Dreambox 500s
ENGLAND
Well I have a new 500s And have set up cifs so it writes to hdd i am using gemi2.20 as that seemed to be the easyest one that worked 1st time
I have the default lang set to english and if needed the audio dropdown to english but when it records to hdd i get both lang at the same time when played back using the pc
Have i still got somthing set wrong in my settings
Cheers Jim
john_graydon
john_graydon
Dublin....Ireland
Cheers Jim
Hi Jim Just a quick reply as its late, they record both languages again you can choose the language in the drop down menu. When recording off the HD to DVD you can select english to burn to disc and only english will be used.
J
jimbo101
Dreambox 500s
ENGLAND
Thanks for the reply John
I downloaded VLC and found it has a choice in the audio menu for lang
so when playing on pc i can pick the lang
Now my next question when playing back via DB how do I stop it playing and go back to normal broadcast channels
Thanks John
Cheers Jim
mhku
mhku
TM Nano ~ sg2100
Midlands
Select 1 from the menu ie MENU > TV MODE.
J
jimbo101
Dreambox 500s
ENGLAND
Thank's Mhku
now i have tryed all the programs that normaly convert ts to mpeg all give the same effect they cannot decode the ts file to mpeg the files play ok with vlc and the db what am i doing wrong i did read some were that it may be the db is encoding them with some other crypt but being new to the db i dont know
any help please
cheers jim
J
jimbo101
Dreambox 500s
ENGLAND
Started usinh ngrab and making mpeg2 its a lot easyer yo make the dvd
thanks for all your help
