- See Signature
- Somewhere in England (possibly?)!
Don't think I've mentioned these before, but, last year, I came across these very useful clips from Screwfix (and probably available from other sources too) which I used to secure bunches of cables on long runs without using nylon cable ties and the like.
They are intended for plumbing use and so come in sizes for the main sizes of small water & c/h pipes. The linked ones are 22mm ones, but they also come in 15mm and 28mm sizes, and these are blue nylon but are also available in red, yellow and "natural colour"!
Very easy to fit (1 screw), AND, to add/remove cables all you do is flip the top part back with a screwdriver blade, and that makes changing your installation quite a lot quicker & simpler
