Advice Needed CM 1.2M parts enquiry
Markjose
Young one with a hobby
Triax 110 ..... No fixed location
Monmouth
Hello All,
I have picked up a CM 1.2 on a well known auction site however I missing am missing bolts to attach the dish to the pole mount. Anyone know where I could get them ? Or have ideas of measurements?
Could also do with some new u bolts but not urgent.
Mark
That was easy and will just measure the u bolts when I have a sec
On the back of this does anyone know the u bolts size for the tm2300 ?
Could you post a picture of the mount you have?
Will do later finally got inspect my purchase and noticed the dish mount looks to be not original thoughts
That was why my question, as original CM mount has no U-bolts. In this case, you can measure an old U-bolt and purchase the same one. Do you have an idea what kind of pole will you use to hang your CM120?
I have a few scaffolding poles concreted in the garden so probs one of them, I'm more concerned about the lack of measurements on the dish brackets, however I guess I could just work out by getting the strongest signal.
This dish will be at ground level and not attached to a house for sure.
No DiSEqC motor based on the Taiwanese designs had U bolts as a clamp, they would be four sides of a hexagon with a toothed plate closed by two 13mm nuts.
Got it now im back home will need to measure and get back to you.
