Confused with Motor settings
jaymes
Likes
Have Hum 5300 . Loaded Pet settings for OAK other models.
Have LNB - Sattelite numbers 1 to 32. There is also motor positions which are different numbers this is my confusion. Also a number of sattelites go to W2 when I go into the search menu.
phillpayne
Likes
humax 5400z patched to hot 11.1, v box mrk2, 1.1m triax dish, jeager 12" activator .6 lnb, modified pet123 settings
kent
#2
hi jaymes,
the sat position No is the basic diqesc 1.2 position, and does not bear any relation to the list No.
ie, lnb 1 astra position 2
lnb 8 amos position 25
this just means your stb needs to be setup to this order
hope this helps
phil
jaymes
Likes
Thanks for reply phillpayne. Clear about it all bar the motor position. This seems to be preset with pet settings with no ajustment in software or STB.
