Oskare100
- Zehnder DR600 digital receiver, 90cm Amstrad dish and one MTI Blue Line 0,2db LNB.
- Sweden
Hello,
About a year ago I tried to get a rotor to work. However, I forgoted to turn off the receiver so I probably short circuited it. After that it started to destroy all LNBs I connected to it with the motor connected. If I removed the motor, then the LNBs worked (if I hadn't tried them with the motor connected). Waisted about five LNBs on that back then...
Now, my question is, when I buy a new receiver (Dreambox DM 600), would you dare to connect the rotor to it? Do you think that it was the old short circuited receiver that was the problem or the rotor itself?
Regards
Oskar
Regards
Oskar
