connecting two KU dish with one set top box
Jigten
DishTV
Himachal
hello friend,
i use to watch dd channels from insat and telstar 10. but i had change the wire everytime as i got two dish on roof but one STB. both the wire of dish goes in to my room. so can any one tell me how can i connect two dish from different sat to one Set top box. so i don't need to change wire every time. Is ther any special connector or equipment for that.
I try to connect both the dish cable and connect it with stb, but i can't search channel. it got hang up...so please help.....if this is success i don't need to buy another set top box.
Yep, go and buy a Diseqc Switch (either 2-way or 4-way) ad they are very cheap too; should be about US$10.
Welcome Back jigten, bigtee is right, buy 4 way, its only 5 $ .
Thank you
I asked this solution to many hard ware shop in himachal, those who deal with cable equipment But they says its not possible to connect two different KU band satellite dish with one Set top Box.
Ok, now i will ask for "Diseqc Switch" next time. may be this is the solution which i was looking for till now.
I am staying little far from town, once i got there definately i will ask for "Diseqc Switch" and i will let you know all.
