controlling sky+ with normal remote- is it possible
jonc26uk
pace sky+
northwest
hi ppli have just purchased a pace sky+ box off flea bay (with remote) works fine everything good, but was just wondering as i have magic eye in bedroom is it possible to program a normal remote to control the basic functions of the sky+ box ie changing channels. or do i need to purchase another sky+ remote thanxs in advancejohn
Info below snaffled from the Satcure website:
">Question:
>How can I control my SKY+ Digibox with an ordinary remote control?
To reprogram the sky remote to control the sky+ box.
The sequence is:
* TV
* Hold Blue+select until LED flash twice
* 2
* Select
* Sky
Now the sky remote up and down channel buttons change the channels on a sky+ box.
To revert back, enter this sequence again but press the zero button instead of "2"."
Also to use 2nd remote in another room, RF Outlet in Sky+ Box must be switched to "ON". (Services 4 0 1 on Remote).
hi thanks for reply, tried it and it works!! but only can use up and down arrow, but tried same sequence but replaced 2 with 1 and everything works!!! all except the record button of course.cheers boys
