Controlling volume on Sky box
Richard_C
Sony Sky box & Win XP
I have an old Sony Sky box which uses a Sky remote "Sky Rev 4".
Is there a way to get the remote volume controls to alter the volume level coming out of the skybox, not the volume of the TV?
Richard
Модератор
On the old Sony one it should be possible but it's within the menu options somewhere.
Not possible on the HD boxes with the new EPG on there - no idea why this feature was removed by Sky....
You can set the output level by going in to setup and then audio. This pre-sets the volume level, it's not something you adjust using the volume control though.
