titinet said:i didn't think so but i have a few channels of can**sat who works
you are right,on "DVB UPLOAD V1.4 site" they says that is a wrong file(fichier bidon)File won't work in the old Coship,it's too big just like the pack "Boston Coship nouvelle version" By the way titinet,does the Truman 9000 emu do se*a 2?
titinet said:there is a another new file "str3680" on the slovak upload center
it's the old "srt3680t*s ok" with k** auto updateIt's a file that would work with the old Coship 2300 I guess(same size and looks similar to the Truman),have had a couple of beers tonight so I can examine it a bit deeper later.Have you read some info about what it can do?
Well the autoupdate has never worked for me,by the way do you have more p*y channels now compared to the Truman emu or is it the same?titinet said:it's the old "srt3680t*s ok" with k** auto update
i try it and it work with the old coship,but no s**2
I have to agree with you that it's the t*s ok bin because you have installed and tested it but when I check it in hex it looks very different to the t*s bin.........titinet said:it's the old "srt3680t*s ok" with k** auto update
no more channels** but the "truman9000" work better and faster than the srt3680Well the autoupdate has never worked for me,by the way do you have more p*y channels now compared to the Truman emu or is it the same?
Is the Truman firmware autoupdating?
Can't remember but if you pm me and give me your mail adress I can send it to you.titinet said:thank 's for the information,but where did you find it?
never seen that software.titinet said:i find an another soft :"asm-dsm"
did you know it?
i try it but it's not easy to compare differents "bin file" because i don't understand what's the signification of the "subroutines"
please post it here so i can have a look!titinet said:i find it at the al7bar.ca
they says that you can edit and modify the bin file but i don't understand how does it work
